DND 9000
- 12:32 PM
- Feb 6, 2016
- Germany
Check the cylinder and piston for scoring, also if you have an air leak somewhere. Are you sure your valve is leaking, did you verify it through the leakage test at your dealer? Maybe try a new solenoid valve.
If all fails, you can try to update to the newer control unit version. Therefore use the m-tronic update kit (1144 007 1801) including the orange pickup body, the white solenoid valve and the control unit with m-tronic v.3.
But try the easy inexpensive things first.
