661 seal problem
super3
8:47 AM
Indiana
661 flywheel side seal is .0025 smaller than the case hole it's suppose to press into.
Bad batch of seals?
Moparmyway
Its just a saw
8:47 AM
In a meeting
I've replaced a couple, they were tight. Are you sure its the correct seal ?
5000+
8:47 AM
pa
.0025 sounds about right. It needs to be a few thou larger, that's what keeps it in place. Try chamfering the opening alittle to help ease the seal in.
Gunn
Yay sawz
7:47 AM
Plover wi
I think he's saying the seal O.D. is under sized and is a slip fit vs press fit like it should be.
super3
8:47 AM
Indiana
I got 2. Both the same.
Correct on the under size seals.
Just use your finger to push it in.
Lightning Performance
8:47 AM
East of Philly
@super3
Been there in the past. The wrong seal size, SUCKS!!!
Plasticote type paint will take up the difference :)
For a fast cure cook those babies under a light.
Never had to do 661 seals yet.
super3
8:47 AM
Indiana
I had them double check the part # for the 2nd one I got.
I'm thinking it is a bad batch of seals from whoever their source is.
Theres no way I would put in an undersized seal.
Same here.
