660 Fast idle solution..........hooray!!
1:16 AM
I just discovered that a standard paint stirrer is 1/8" thick and 1 + 1/16" wide. Maybe with some good grease, they will hold up for a while!
At least it is an easy way for me to try out if it works with the Asian saws.
jmester
1:16 AM
VIRGINIA
Yes I still have some. Sorry been busy and not around much. Pm me your address and I will send you a couple.
keukadan
1:16 AM
NY
I just received my printed block and am here to report it solved my fast idle issue. Thank you to everyone who made this solution work out, I greatly appreciate it.
1:16 AM
Pic of the installation … do they work on Asian saws?
jmester
1:16 AM
VIRGINIA
I would think they should because the Asian saws are based off oem. I can send you a couple to try. Shoot me a pm with your address.
jmester
1:16 AM
VIRGINIA
Mike,
I sent you a couple in November. Do you need a couple more?
jmester
1:16 AM
VIRGINIA
Everybody that messaged me about shims. Your stuff went out today in the mail. Mr. Young yours will go out tomorrow.
jmester
1:16 AM
VIRGINIA
Mr Young yours are on the way
Rsrobins
Active OPE Member
10:16 PM
Washington
Ive been scouring the internet to try and figure out my high idle issue and came across this awesome sight. I joined the group and came across this thread. I tried making my own version of the diagram that was posted but it didn't fit right. Any chance you have any of these left? Thanks,Rich
Wood Doctor
Edwin
12:16 AM
Omaha, Nebraska
I knew I should have patented this and sold it. My error. I think the supplier (jmester in MD) should have some left. This also fits an 066 and a 650 should they be having the same problem. The carbs need a fast idle to start the engine cold. They seem to start OK when warm but not cold without the fast idle.
Rsrobins
Active OPE Member
10:16 PM
Washington
My saw is actually an old red eye 066. I put a new tank on because my old one was leaking and had a busted ear for a mount. This new handle hasn't worked right since i put it on. Definitely need the fast idle for cold start!
1:16 AM
As a first step, swap the OEM control levers to the new handle.
Rsrobins
Active OPE Member
10:16 PM
Washington
The old control lever is a completely different design. A better one at that. I tried to make it work . But it won't fit.It was one of the old red ones with a big circle on the shaft right where the new ones need a shim.
