Willoughby
I have built 3 of these saws 1 for my son 1 for a friend both were stock and run well , then I built me one with a hyway 56 mm BB cylinder, when I measured squish without a gasket it was .019 so I went with that , the 2 stock saws had enough compression that if you failed to reset the de-comp after they coughed -it hurt - Im am 61 with a few health issues , but Im not that weak , at least imho, this BB saw kicks the decomp off in 1/4 of a pull , I did get it started but I think I need a D handle off a sno mobile - where can I find these ? and should I add a base gasket or run as is at .019?
also I am having trouble testing compression , Ive tested some old macs 65 psi and 100 psi , but I cant get a good enough pull for these chinesium 660s , maybe I am getting weaker , Im using a tester ive had for years , im a retired auto tech , some where I heard auto comp tester may not work for saws ? I cant see why not -but educate me -Im here to learn -tell me how to test compression on these C660s & point me to the D handles please --any help -advise much appreciated, thanks in advance for any and all replies
