562 oil pump drive.
Stevetheboatguy
11:48 PM
Nw IL
So... When did they change?
Received a 2020/21 562xpg that was replaced under warranty. The saw had the drum and a few smalls robbed. No biggie. I did my thing and got it all back together, grabbing parts from my used box. All seemed fine. That was this past winter. Fast forward to now. Loaned the saw to a friend and he had a starting problem. Nimrod that put the airbox on had the choke in the wrong slot. Oops that was me, my bad... easy fix. I go to test cut the saw and it only oils intermittently....... Great. Tear into it because I need a saw and all my others are stored except a handy dandy craftsman and a 201. I pull the clutch off and the used drum has three prongs to drive the gear. The gear has a large spline...... Wasn't going to wait for a new drum and drive to come in. So I grab a 359 drum that has been on my bench for well um years. It's almost a dead nuts match. The clutch had a slight drag on the drum as the backspacing is slightly different. A reduced diameter washer, a quick start, piss rev with the brake on and we are back in biz. Full send.
:afro:
Will find the proper parts at a later time. But why would they have to change something like that?
:nusenuse:
Steven
bradb123
11:48 PM
wisconsin
Make sure you get the right oiler parts . I have 2018 , 2020 , and 2021 562s . The worm drive is different on my 2021 than the older 562s .
Stevetheboatguy
11:48 PM
Nw IL
I was probably going to order a drum and worm as a package from a older ipl. That way it didn't matter and they would match my other 562. But who knows...... Maybe I'll just run it how it is. Can't sell the thing so why put more $$ into it.
Steven
bradb123
11:48 PM
wisconsin
Steven
The change took place in the 2020 model year . Serial # 2200049 is when the change happened .
