500i questions
StihlEchoingHusky
5:16 PM
#1 this one is just coursity. The crank case ports has anyone done anything to them? Like the little section of gasket. Would cutting that open it up any? Ive noticed it's not connected to the lowers divider. unlike divider in a 372 boot.
Okay for the question that's most important. what or how do we clean the injector? I didn't see that in the service manual. I could have completely missed it. My Minds been running a million miles on empty as of late, so I apologize if I've missed that part! I've got two types of injector cleaners (a 12v that you press onto a can of carb clean and a multi injector machine) but I don't know if there's an adapter or something to make either fit.
2000ssm6
8:16 PM
NC
Not sure on #1, one of the builders will have to chime in.
For #2 unless you have a bad fuel line or filter, I wouldn’t worry about cleaning the injector. I’m sure the processor will let you know if either have issues. Stihl might have a tool, probably cheaper to replace the injector being there is only 2 units that are FI. I’m waiting to see when the aftermarket will release a bigger injector for the builders.
Ketchup
Epoxy member
6:16 PM
Colorado
Report back on #1 if you do it. I’ve been tempted but left it alone. Across several Stihl Models. Because it isn’t continuous to the cylinder it seems like it would create turbulence. But it’s very far from the uppers. It may serve to organize turbulence from the case earlier in the transfer tract. The not so secret sauce to the front fed transfers is how well they aim the flow of the uppers. Anything that makes that flow more linear is good. IIRC, Husky 5 series does not have a gasket piece in the case lowers. Maybe someone can confirm that.
Don’t clean the injector unless you know it’s dirty. In that case you’re probably in for a new one so what can it hurt? Standard carb cleaner or Ethanol are probably better than proprietary injector cleaners designed for automotive.
You may be able to pump from the primer through the injector while the parts are off the saw. I can’t remember if the injector piston will open during that process. If not you may have to rig up a battery system to activate the injector (best guess is it’s 4.5-6V system). That avoids introducing cleaning agents into the rest of the saw.
Whatever cleaner you use, don’t soak it. Just pump some through and then get non-ethanol mix back into the system. That should preserve the rubber parts best. Most rubber degrades from ethanol bonding to ambient moisture over time not from short term exposure.
The CPU may tell you the injector is bad in certain circumstances, but it has extremely limited capabilities. My injector did not read as bad even though fuel was actively dripping out of the vent. I would not rely on it for diagnostics. Standard trouble shooting is necessary.
Great saws but parts costs add up quickly. It really helps to have a known, good, stock saw to swap parts with. That’s basically what the dealers do. The MDG1 system is a huge disappointment. It makes the saws software dependent for resets but does extremely little for diagnosis.
Take anything I say with several grains of salt. Almost all my 500i experience is with one saw. It was a 2 year saga to get it running and I replaced and messed with almost every component of the saw. In the end, the problem was a rare one. I had a bad stator wire, the injector was probably broken from excessive priming. Vapor lock/hard restarts are more common than my problem. If that’s what you’re dealing with I’m not much help.
EFSM
7:16 PM
Extreme southern IL
Injector cleaning usually consists of removing the carbon buildup from the tips. That is a result of the injectors being in the combustion chamber (direct injection) or from EGR (in a port-injected engine), neither of which is applicable here. If the fuel filters are maintained, these injectors should be astonishingly reliable.
Outback
5:16 PM
Why do you think the injector needs cleaned?
StihlEchoingHusky
5:16 PM
The guy brought the saw and it's contents to me in a litter box.... Ok not really a litter box but it was damn near that. He had it stored in a hayloft in the high desert part of Oregon for 3 years. The injectors are spendy and I'd rather try to reuse if possible. Ive already replaced the pump. The original one I didn't want to bother with because the diaphragm was toast and Metering lever was sticking (do to a bent pin) and the screen..... Oh wait! I'm sorry the lack of a screen..... dust was completely filling the thing.. with that I believe the injector has dust clogging it lol
Outback
5:16 PM
You gotta flow to clog. Makes me wonder if its stuck from cooking in the summer. Do you have an ultrasonic you can toss it in? Why was it parked in the hay loft in the first place?
Sloughfoot
5:16 PM
Norcal
sounds stolen
StihlEchoingHusky
5:16 PM
Yes I do but it's The small central machinery one.im pretty sure it's a dud lol. Why he stored it there is beyond me. He said that it started running away from him one day..... I didn't say this out loud. but in my head I said , AHH the classic $1500 saw with an air leak so let's through it in the barn manuver! It's a tried and true repair tactic employed by masters of their craft!
Or maybe a logger's saw. It broke, he bought a new one to keep working and threw it to one side so he could "fix it later" and he never got around to it.
Not a logger. He is an alfalfa farmer.
Ketchup
Epoxy member
6:16 PM
Colorado
Have you pressure tested it? An air leak would be good news. I would just clean everything enough to not introduce dirt and put it back together. In particular, don’t mess with the injector, or the pressure sensor. Just get the dirt off them. Be careful with the wires on all electrical components. Finding an intermittent short is hell.
Outback
5:16 PM
You have put some mix down the intake to prove it is just the fuel system right?
I put things in my barn that I lie to myself about fixing "soon". Sometimes I realize that its been years since I last entered one of my outbuildings. Don't be too hard on the farmer.
StihlEchoingHusky
5:16 PM
I think you've just explained what life is like for any human 🤣 don't we all have projects that we will get to..... Eventually?!?!
Your right! That's why I didn't actually say anything to the guy. Most of the time when I *b-word about something it's more of a venting process. We all have our places in this world and if one goes out of whack the rest can suffer. By that I mean farmers produce the food,truckers ship,mechanics like myself make sure the first two have what they need operating properly ECT ECT. But the exception is if your a Chrysler engineer... go to hell!! 🤣🤣 I'm just kidding!
