461 base gasket
paragonbuilder
11:39 AM
Norwich, CT
I measured the base gasket again, mine is .0170. I didn't have any clearance problems with the c and stuffer bolts. Cylinder went on fine.
Should I try to flatten the solder down to .030 prior to putting it on the piston?
Trouble with flattening it first is as it gets wider it harder to crush. Best to get thinner solder or plastiguage.
paragonbuilder
11:39 AM
Norwich, CT
But I'm thinking in a pinch. You could flatten it to a measurement and then check and keep going til it spins past with out bumping.
ffchewy17
11:39 AM
Lake Mary FL
Rechecked the squish with the saw assembled, through the spark plug hole, came out to 0.014 with out base gasket. Reassembled saw with base gasket and it was .030 , with new piston and rings compression was at 185psi.
mdavlee
Hillbilly grinder
11:39 AM
TN
If you want to do a gasket delete take the old piston and stick on sandpaper and something to push it and twist. Won't take long to get enough clearance. Then clean and assemble again with sealer
paragonbuilder
11:39 AM
Norwich, CT
This is how I do it now. Works very quick and easy. I used super 77 spray to stick it on but it takes a bit to dry. I just bought some paper with adhesive on it but have yet to try it.
11:39 AM
No, they are sanding the top of the cylinder (on the inside) using sand paper on the "OLD" piston (called cutting the squish). Just rotate the piston back & forth. It will produce the correct clearance between the piston & cylinder (measure frequently).
mdavlee
Hillbilly grinder
11:39 AM
TN
You could sand the top of the piston. Piece of glass or tile.
