.404 chain swap
Evansaw
4:08 PM
Greece
Hi all
I m swapping the nose from 3/8 to .404 at a Stihl 3003 bar
Bar is 30 inch and while 3/8 is 98dls
Anyone know how many DL would love the .404 so i can cut the chain?
hacskaroly
2100 Fanclub Member
7:08 AM
Northern Idaho, Ehh
When I was making chain for bars that did not match the saw and the drive count was off (usually one longer or one shorter than what it should have been), I would go one or two links longer, mock it up on the bar and see where it ended up and knocked off how ever many links it (usually only one) to get the length it needed. I tended to use junk chain that way I could butterfly in a few lengths if the chain was not long enough and then knock out what I needed to get the correct count and then make up the good chain with the number I figured out.
Evansaw
4:08 PM
Greece
Here is a link to Stihl's site with info:
STIHL Rollomatic ES guide bar, .404", 1.6 mm
Part Number: 30020009741
Yep but 3002 is bigger bar for the 120cc saws, so for sure the dl are not correct for the smaller 3003
So if 91dl at 3002 then should be 5-6dl less out in 3003
Logic comes to 85or87links max total for 3003
I ll inform when i cut the chain
Squareground3691
10:08 AM
New England
ferris
3:08 PM
Germany
Hi all
That’s at least the second bar u convert to 404.
What’s ur reason for that?
Eduardo K
Just another tourist…
10:08 AM
Baldwin, MD
Sitting in traffic, my wife is driving so I did some math.
There are two links for each driver, so we double the pitch and multiply it by the driver count.
3/8 pitch doubled - 3/4” or 0.75” per driver, .404 is 0.808”.
The 3/8 chain for you bar has 98 drivers.
98x0.75”=73.5”
Then divide the length by .808.
73.5”/.808=90.965 or 91dls
My wife tailgates in traffic so I have to look down when I’m in the passenger seat.
Good luck.
Evansaw
4:08 PM
Greece
Cause there is no .505
Well actually i got variety of trees and some are just killing the 3/8, wood being dirty or not. And of course for those f***** palm trees every know and then the .404 is the best solution
Philbert
Chainsaw Enthusiast
9:08 AM
East Dakota
98x0.75”=73.5”
‘3/8’ pitch is a nominal measurement; like 2X4’s, or ‘foot long’ hotdogs.
100’ x 12” / foot =1,200 inches
1,200 inches / 1,640 Drive Links = 0.73 inches per link. Divide by 2 to get actual pitch of 0.365” (not 0.375”).
(*** Don’t share this with folks who are easily triggered! Next you will have to tell them where the REAL ‘rakers’ are on the cutters, and that the gullet doesn’t cut!).
Philbert
