WANTED 395 low top setup
jacob j.
Only the weird
12:02 PM
Coastal Oregon
I think I can set you up with the correct low top elbow. I may have the correct low-top cover for the wider clips as well, then you can make your own seal between the elbow
and cover.
srcarr52
3:02 PM
Iowa City
and cover.
It would probably be best to remove the rubber rear carb mounts and make solid spacers for the filter neck. Or go to the 394 carb shelf, but nice ones are hard to find.
davidwyby
Rural desert logging
12:02 PM
Extreme Southeast CA
That’s what I was thinking.
