- 4:30 PM
- Jan 8, 2016
- Farmington, CT
Ya...I'll get one...no worries
My 94 seems to mill happily at about 8,400-9,000 but very much wide open throttle....lower rpm than wot
346 coils on the 372.He said he had a few buckets full of some sort of limited Husky coils. Must have been another model?
Matt you got a p/n for the coil and where did you grab it fromI have a new coil ordered....we shall see if that helps.
Carb is probably a fresh rebuild. But that ll be next
thanks Matt , in case i need one
Raise the pop off pressure, the needle is opening to easy and dumping extra fuel. Making your four stroke tune actually to lean in the cut.
Stronger spring?
