Timbco84
I just finished porting a 394 and now at full throttle with the high speed needle all the way in, the best i can get is 11,000 rpm. At 1 1/4 turns out it is pig rich and like 7,ooo. Low speed needle and idle screw adjusted with tach and in spec. I thought I found the problem when I pulled the carb and the metering lever was way high, but set it with the walbro guage to spec and same problem. Was a good known running saw before port work and original owner saw.
Walbro Kit in the carb
New fuel filter
New air filter
New spark plug
Passes vac/pressure tests
I didn't widen the ports at all
I didn't raise the intake roof at all
I didn't lower the exhaust floor at all
I port matched the exhaust-muffler and added a port to the muffler
I cut the jug in my lathe and took the squish down to .024
I advanced the timing 1/4 of the key
I set it at 20 degrees blowdown
I increased the intake duration 8 degrees (156 Total)
Took exhaust back to stock height after lowering the jug
Compression is up 20 psi after lowering the jug and is good
Throttle is reaching full throw and cable is not stretched
I can't imagine that the extra 8 degrees of duration on the intake would cause this problem... but I am still learning porting, and this is the first saw I have adjusted the port timing on.
Please help, if the added intake duration is not of concern, I think I need to consider trying a new carb next.
New fuel filter
New air filter
New spark plug
