372XP X-torq 75cc Conversion & Porting
12:15 PM
Thanks Mike, I always manage to confuse the nomenclature. Makes me second guess leaving them there.
I tried one like that. Didn't have the high rpm power. It was ok at lugging
XP_Slinger
They’re Just Saws
12:15 PM
Central NY
Transfers are where it really sucks to be a stuck with a dremel. Raised them to 123*, but this is the best they're gonna look. Entry angle isn't flat either, but I know another XPW ported like this and it runs HARD.
XP_Slinger
They’re Just Saws
12:15 PM
Central NY
Ok so I'm saying goodbye to my pride so others can see how easy it is to make a mistake if you're not thinking 100% of the time. Marked my piston, took the cylinder back off and started grinding. Sounds normal right? Well, I stopped thinking and started grinding on the top of the intake port! Idiot! As you can see in the pic the lower ring is partially exposed. Luckily the locator pin isn't. I don't feel good about it but I chamfered the hell out of it and I'm gonna cross my fingers it doesn't snag. Lesson learned, slow down and pay attention! Always!
RIDE-RED 350r
12:15 PM
Blossvale NY
Looks good, and all you can do is give it a whirl. I hope the intake doesn't cause a failure because I want to see how the two XPW's compare.
bikemike
11:15 AM
Cottage grove mn
Time to remove a ring
