XP_Slinger
They’re Just Saws
- 11:58 AM
- Feb 9, 2016
- Central NY
Since the XPW cylinders are NLA I’m going with an OE 50mm.What cylinder are you going with?
I’ve done divider in and out, in seemed to be more stable with it in but it never settled safe enough for me to trust it. I might flood her out good after going rogue with those tiny drill bits...lol! Never know til you tryI have 7 different saws with RWJ’s and none of the jets have been drilled. The dividers in the air filter are gone. They are a bit sensitive to keep adjusted in tune though, best be having a screw driver with you. My experience with them has been how Kevin explained it, in short cuts they do act rich until they get good and warm then come right out of 4 stroking under load
Meh, I shot myself in the foot. Drilled too many things lol.Nuffin like a good ole HD or C3m for a worksaw I guess. Less screwing around... literally. Lol
They’ve always worked pretty good for the most part for me on 372/7900 series saws. The HD or a WJ/tilly does make a little more power/torque, but you don’t notice it unless you swap the carbs back to back or if your saw is modified. I like them all better than the rwj for sure though.+1 for c3m!!
Thanks, but I have to experiment with this.Ive got a brand new zama clone carb here if you want it.![]()
Ok, bear with me as I walk through what I did and what I learned.
Original problem - wandering tune with stock RWJ-4 carb on an OE 372 cylinder (non X-Torq). Tune would get leaner and leaner and could be tuned safe with both L and H screw out 3 to 5 turns depending on the time of year. With the jets way out, the next cold start would be pig rich and I would have to chase the tune all over again. Something just wasn’t right. What I needed was more fuel supplied to the jet screws.
So for the good of the community I did some experimenting based on advice received in here from some of the best carburetor whisperers. I also took things a step further in an effort to give it more fuel at every throttle position.
So here’s what I learned...
Blue arrow - Main Jet
Yellow arrow - Second Stage Transition Supply
Red arrow - Supply to Welch plug area (green)
Green arrow - Normally covered by Welch plug, contains L screw circuit supply and first stage transition (2 small holes in the middle)
Main jet was marked “51”, I drilled it to .6mm.
Welch plug feed jet marked “38”, I drilled it to .5mm
Second stage transition jet was marked “30”, I drilled to .5mm. Thought to myself “you want fuel? I’ll give you fuel you sombitch.” Lol!
It’s no surprise that when I put the carb back on that it was Pig and I mean PIG rich at half throttle. The first and second stage transition circuits feed directly into the bore of the carb under part throttle before the main jet takes over. First stage under Welch plug, second stage yellow arrow. Both first and second stage transition circuits are off shoots of the L jet circuit. So drilling those jets drastically bigger, flooded the saw out at anything other than idle or full throttle. Which makes sense because the transition circuits almost turn off at WOT because of the loss of vacuum. WOT is 100% main jet (H) and very little idle fuel (L) as far as I understand it.
I’ve gotten some ideas of how to salvage this from a friend, more to follow.
Yup you’re right on the money Mike. Explanation to follow with a pic for those of us that are not so carb savvy. Long story short I fixed itThe transition jet and under the Welch plug you went over 82% in size gain is where the problem was. .51 to .6 wasn’t too bad. About 38% more fuel. The one was 167%. You might be ready for some methanol/nitro on that carb. There’s a few tricks to close them off and start over.
That sounds really close to where this BB Dolkita needs to go. It is lean real bad anywhere off idol. Nothing has helped with carb swaps. It wants more. Gets hot quick even in cold weather and won't fourstroke. Starts out set all fat....runs good for three cuts and goes way lean. Stop for a minute....try again and it stumbles and then revs to the moon.Ok, bear with me as I walk through what I did and what I learned.
Sounds EXACTLY like what my saw was doing except for the stumbling part. Frustrating as all hellThat sounds really close to where this BB Dolkita needs to go. It is lean real bad anywhere off idol. Nothing has helped with carb swaps. It wants more. Gets hot quick even in cold weather and won't fourstroke. Starts out set all fat....runs good for three cuts and goes way lean. Stop for a minute....try again and it stumbles and then revs to the moon.
