- 12:18 AM
- Dec 31, 2015
- East Jordan, MI
Your saw doesn’t continually keep leaning out though once you’ve made a half dozen big cuts like that though, does it? If it did, then I would think you had a problem. Anytime you add heat, it requires more fuel. No different than tuning for a short bar versus turning for a long barWell here goes. The RWJ has a large venturi but in its original application on the XT saw only half of that Venturi was used to deliver atomized fuel to the engine through a VERY small intake port/tract.
Now, put the RWJ in an intake tract that is not divided for fresh air strato stuff and you’ve essentially doubled the volume of air that is mixing with the same amount of fuel as it passes through the Venturi at lower velocity...which is another aspect I’m thinking about. Being lower velocity, it’s likely not the same amount of fuel. Yes, my divider is in place in the carb, but after the divider is where I think the fuel/air ratio is getting screwed up and causing the saw to eventually go lean as it gets hotter and hotter.
I’m thinking the fuel jets in the RWJ are designed to deliver fuel to half the volume of air that my saw is pulling through the Venturi because there is no separation between the fuel side and the strato side as it is on a stock XT saw.
I’m sure there are some details I’m overlooking, but that’s where my brain is at right now. Still thinking through some velocity vs volume stuff in the intake tract but I think I’m understanding why fuel mods need to be made to make this carb play nice with non-strato saws.
This thinking is leading me to one verdict...the large Venturi of the RWJ is a deceitful SOB and might not lead to “gains” as easy many of us think it does. It is essentially designed to deliver fuel using a 9.75mm venturi with higher velocity. Or half of it’s total Venturi area which is somewhere slightly north of 19mm if I recall correctly.
