decableguy2000
I have an Ebay special 371 that I bought, that was advertised has having an air leak. I went through it with a fine tooth comb, new seals, gaskets, P&V tested less than a 1/4 tank later air leak. It was on the clutch original, I don't have tore down yet, but have a feeling its there again. Anyone have a better way to see where its coming from on that side of the saw. Its real busy in there. Also do you install the seal and then the sleeve or the sleeve than the seal
