361 oiler help
big t double
You can call me Teddy Eastwood.....
12:13 PM
its 1135. they use the 1125 chain adjuster...id like to see the saw or get the serial number.
1:13 PM
they used the 1125 chain tensioner on alot of saws but id say the cases will have 1125 on them as well like ted said the 361 is the 1135 series another way is to check the mounts there will be a spring mount from top handle to the cylinder and on the 036/360 there wont be any spring suspension at all
big t double
12:13 PM
if you have media cat then you probably already know...but the oil line kit for that saw is 1124 007 1010. have fun.:D
1:13 PM
on the 036 /360 the hose is long enough to gt 2 pieces from
1:13 PM
dont think it is ted gave the part number i know dave has them or a dealer close will have it
big t double
12:13 PM
its not the same hose material as the impulse....its a lot harder. Ive read around these parts that using a softer line will get hot and collapse. I don't know if that's true or not....but its gotta be, I read it on the internets. now maybe if a guy were to use the spring that goes in the oil line off the 1120 series...that might work with the softer line. 1120 series use the same size line as the hard oil line that comes in the kit. I believe the impulse line is a larger size. 0000 997 0225 is the spring that goes in the 1120 line.
