SOLD 36” Cannon 3002 Mount
Wolverine
dilligaf
6:16 PM
I just bought one of these locally for a steel. It's made maybe 1 or 2 cuts. About to buy an adapter to fit my Doo9 mount. Any advice for those Cole? Don't think those spring type pieces are the way to go.
Armbru84
Just trying to get by
6:16 PM
Michigan
Eh I didn’t have the best of luck with those springs either but in the end they did work. I ran it on my 084 I had awhile back so I didn’t really have to use it on my 3120. Those springs but a pc that’s the same width the whole diameter would work well.
Armbru84
6:16 PM
Michigan
Actually found another chain so it will have 2 chains with it.
Armbru84
6:16 PM
Michigan
is it .404 .063? how many dl? do they make an adapter for a large mount husky(d009) to fit a 288? thanks!
It is .404 .063 with 111 Drivers. They do make a few different adapters which is what we were talking about above. Cannon has a few available and there may be others.
roger collins
5:16 PM
jackson,ms.39209
thanks-any idea on shipping charges to 39157 ridgeland,ms.? are both chains full chisel?
Wolverine
dilligaf
6:16 PM
Dolkitafreak
Dolkita686
6:16 PM
Central Ohio
https://www.newenglandpine.com/product-page/gb-titanium-bar-adapter-gpsb9-14-9mm-to-14mm
This is advertised as 9mm (D009) to 14mm (3002). I ordered one after not getting a reply from M.Manley. Also, I've found with using an adapter from D009 to 3003 you may need to add one link to get the chain up over the clutch drum.
I think the extra link will be a non issue as the slot is much longer in 3002 bars due to stud spacing, so the length of slot is closer to husky bars. Should just need to adapt for diameter of stud me thinks🤔
Armbru84
6:16 PM
Michigan
Small world…been there a few times. I wouldn’t know until I boxed it. Shoot me a pm with your address and we can figure something out. We can cap it at something if you want.
On the chains I have a ton of 404 so I can make almost anything. The ones I have now are full chisel and 1 is square. I have skip round and some semi chisel too. I do also have some of those adapters I put the link too Baileys on.
Wolverine
dilligaf
6:16 PM
That's good to hear. I borrowed the other long bar set up for a milling job so I couldn't add the link. I ended up removing the clutch to make it work. PITA.
roger collins
5:16 PM
jackson,ms.39209
roger collins 619 old agency road ridgeland,ms.39157 bar, adapter and two chains(full chisel skip round)
