is it .404 .063? how many dl? do they make an adapter for a large mount husky(d009) to fit a 288? thanks!Actually found another chain so it will have 2 chains with it.
It is .404 .063 with 111 Drivers. They do make a few different adapters which is what we were talking about above. Cannon has a few available and there may be others.is it .404 .063? how many dl? do they make an adapter for a large mount husky(d009) to fit a 288? thanks!
thanks-any idea on shipping charges to 39157 ridgeland,ms.? are both chains full chisel?It is .404 .063 with 111 Drivers. They do make a few different adapters which is what we were talking about above. Cannon has a few available and there may be others.
Cannon Chainsaw Bar Adapter Spring (9mm to 14mm) CBW-87575
Economical bar adapter from Cannon. Simply slip these adapters over your bar studs and you can run larger mount bars (14mm slot Stihl bars and double ended chainsaw milling bars) . Sold individually.www.baileysonline.com
https://www.newenglandpine.com/product-page/gb-titanium-bar-adapter-gpsb9-14-9mm-to-14mmthanks-any idea on shipping charges to 39157 ridgeland,ms.? are both chains full chisel?
I think the extra link will be a non issue as the slot is much longer in 3002 bars due to stud spacing, so the length of slot is closer to husky bars. Should just need to adapt for diameter of stud me thinkshttps://www.newenglandpine.com/product-page/gb-titanium-bar-adapter-gpsb9-14-9mm-to-14mm
This is advertised as 9mm (D009) to 14mm (3002). I ordered one after not getting a reply from M.Manley. Also, I've found with using an adapter from D009 to 3003 you may need to add one link to get the chain up over the clutch drum.
Small world…been there a few times. I wouldn’t know until I boxed it. Shoot me a pm with your address and we can figure something out. We can cap it at something if you want.thanks-any idea on shipping charges to 39157 ridgeland,ms.? are both chains full chisel?
That's good to hear. I borrowed the other long bar set up for a milling job so I couldn't add the link. I ended up removing the clutch to make it work. PITA.I think the extra link will be a non issue as the slot is much longer in 3002 bars due to stud spacing, so the length of slot is closer to husky bars. Should just need to adapt for diameter of stud me thinks
roger collins 619 old agency road ridgeland,ms.39157 bar, adapter and two chains(full chisel skip round)Small world…been there a few times. I wouldn’t know until I boxed it. Shoot me a pm with your address and we can figure something out. We can cap it at something if you want.
On the chains I have a ton of 404 so I can make almost anything. The ones I have now are full chisel and 1 is square. I have skip round and some semi chisel too. I do also have some of those adapters I put the link too Baileys on.
