357/ 359 muffler's
Kiwioilboiler
346 Pic Examiner
6:09 AM
Marsden Pt, NZ
Yes that is true, I prefer an empty can for other reasons. My personal belief is the muffler acts as a mini expansion chamber. 372, 390 don't have a divider and I feel the empty can does well on these saws. I might be full of ear wax on that subject but gotta believe in something right?
Oh for sure. But i'm a 90 10 guy. 90% of available result is fine with me if i only expend 10% effort in getting it, because the next 10% normally takes 90% more time and effort to achieve.
Funky sawman
Pony Power
11:09 AM
North idaho
You can drill through the exhaust opening and grind as much as you want from there. That should help your front exit port. Here is a pic from mine before it was finished.
Then I would have to just figure out how to hammer the front cover bumps flat from inside with a flat chisel I guess
Ronaldo
1:09 PM
Eastern Iowa
AM have the same partition wall that the OEM have. I used a tube and drilled and ground as much if the wall as I could from the back. Let me knownif you want to see inside pics.
I did mine the same way. 1/2 size drill bit if I remember correctly. Drill through the baffle plate as many times as possible from the back (cylinder) side of the muffler. Then I put a pipe in, but I dont have to run spark screens here.
Sent from my SM-G930VL using Tapatalk
