Simpsonsawshop
- 3:54 PM
- Apr 17, 2020
- Townsend
This is a customers saw. About a year ago, I did a mild port job, muffler mod, base gasket delete, and new ring. The saw ran awesome for about 3 months then started acting like it had an air leak. Quick and dirty test with some carb cleaner indicated a leak in the inake boot area so I tore it back down and replaced the intake boot, pulse line, and factory metal pinch clamp with a worm clamp. Fast forward to now. It is doing the same thing, carb clean test shows a leak in the intake area but it passes a pressure and vac test with flying colors which suggests to me that the carb isn't sealing to the intake and my rubber block off is sealing it up.
What gives here? Is there a common problem that I dont know about? Warped plastic divider maybe? Gimme some ideas guys. This guy is an arborist and needs his saw back asap.
