346NE vs 254XP vs 55CP...Sibling Rivalry. Results are in!!!!
beaglebriar
The Peanut Gallery
1:20 PM
Warren Center, PA
A muffler modded rematch might be all it takes, those 346's are pretty stuffed up and wake up considerably just clearing out metal under the stock deflector.
That was an interesting and entertaining match, thanks for the vids and such.
Muff mod and trim the limiters so it can actually be tuned.
12:20 PM
That's what I would like to see first before all the grinding starts.
XP_Slinger
They’re Just Saws
1:20 PM
Central NY
I’ll be the first to admit Joe’s 346 isn’t performing to its potential, but his little match was about both saws being stock guys. I’ll oblidge another run with the 346 modded and I’m sure Joe would be willing too. But don’t be surprised if the results are the same, the 254 is still sporting a 4cc advantage which is substantial over a 50cc Saw and on top of that it’s safely tuning to 14.3k. That fugger is stout.
RIDE-RED 350r
1:20 PM
Blossvale NY
First time running it, and I really like it!
They aren't a big HP saw and run out of steam in larger wood, but they sure scream in the stuff they like :)
Being a non-top-handle pint-sized Mini-Me of the 288 is what trips my trigger with them..even has that ting-ting-ta-ting of the 288 albeit a bit higher pitched
XP_Slinger
They’re Just Saws
1:20 PM
Central NY
Going back in the thread a little @skidder was trying to decide on his next project. How’s this for ya Moose? I think you should get a 372, this is the same log we were cutting on yesterday. Started cutting where the 288 left off. So what ya think squatch? The 372 is every bit as iconic as the 288.
cgraham1
10:20 AM
Nor Cal
Yeah, I couldn’t lean on it on the big end of the log (12” or so), but under about 8” was where it really shined.
PA Dan
FYD
1:20 PM
White Oak PA
Or put a muffler like this on it...
RIDE-RED 350r
1:20 PM
Blossvale NY
I have a 1" outlet like that on my 288....but I'm not posting pics because I had a hell of a time welding it! It's fugly but it works. Lol! We don't have the best welder for that thin, soft, muffler tin. Does sound good though and I suppose it helps it breathe better
Tor R
Novice, Leg model #2
7:20 PM
Mandal
Here’s the averages for small and big wood for all 3 saws.
I wasnt surprised that 254 won it.
Lightly modded, the difference may be even bigger, 254 has a very restricted stock muffler, and it loves advanced timings not sure if the 346 can catch up if both should be lightly modded.
Fully ported I would still bet on the 254, its hard to beat a saw who has 4cc extra if it run with 210-220psi.....
XP_Slinger
They’re Just Saws
1:20 PM
Central NY
I agree Tor, 4 cc is a big advantage over a 50cc saw, almost 10%. I’m going to leave my 254 stock and Joe is going to mod his 346 then We’ll do his again, we think it will be interesting to see how the gap closes as the 346 is progressively modded.
12:20 PM
Especially since it's plus 4cc in the stroke. Makes you wonder why they went backwards with the new model?
1:20 PM
The 550/2253 have a 34.5 mm stroke and crank stuffers. That’s a longer stroke than a 272. 562 has same 36mm stroke as a 372. The 572 has a 39mm stroke, longer than a 288. Seems like there going to longer stroke in the new models.
