cuinrearview
Handy dood
- 3:03 AM
- Apr 16, 2019
- Dowling, MI
Was your fitment similar to mine here?in East-Europe![]()
very similar.Was your fitment similar to mine here?
Tell me more about this bj weld...Cool idea.
Will the piece plastic fit inside out on the stuffer?
Could rough the surface up and smear some bj weld in there to close the gap and stop the rotation
Usually has a happy endingTell me more about this bj weld...
Autocorrect finally got it right...Tell me more about this bj weld...
The plastic is molded to the metal cup. It only came off because I sanded it down. I could re-use it, but if I'm going to take up clearance I'd rather use something else I think. When I mentioned using it on the PTO side I meant like this.
I'm leery of filling in between the counterweights and cup because I don't want to screw up the balance of the crank.
More on the why I did its later, but for now let me say the Golf 44.3 pistons are *s-word. The rod clearance difference is not an optical illusion. This is what happens when I don't follow the "no AM junk" rule...
On the right is the original 42mm piston. Let the ball busting commence. I'll be on Ebay picking up a Meteor...
Lesser crankcase volume...more of what the piston displaces on the down stroke ends up coming out of the transfersWhat's the point of the stuffers? Just more counter weight? Vibration reduction?
Illusion. I took pics all the way around I must have deleted the bottom one. The clearance is pretty even all the way around.Is it an optical illusion, or do they get pretty close to the case on the bottom?
Thanks Brett. I only have the lightly massaged 2147 and 350 at home to run it with. I'm not certain if you'll allow it on the property once you see it thoughSwing by when your ready for some testing.
Anytime.Thanks Brett. I only have the lightly massaged 2147 and 350 at home to run it with. I'm not certain if you'll allow it on the property once you see it though. I'm taking steps to make it extra ugly...
