346 OE intermittent bog, won't reach 13k RPM, Revisited FIXED!!!
decableguy2000
12:23 AM
WNC
I assembled this saw from new and used OE parts a few weeks ago. Was cutting some dead yellow pine and I could make 3 cuts than it would bog, make a cut bog, 3 more than bog. Pressure and vacuum tested good when I reassembled, new Zama EL18, new intake, vacuum line, New Caber ring, and aftermarket base gasket. New plug, tank vent, and fuel line (I think, have 4 saws on bench). I have a few extra parts to try and swap if need be. I'm thinking fuel related but, I can not confirm or deny.
RIDE-RED 350r
12:23 AM
Blossvale NY
Just for the sake of redundancy, try running it without the fuel filter. I had a head-slapping moment with my 242 awhile back regarding a fuel filter that looked descent enough but didn't flow enough.
decableguy2000
12:23 AM
WNC
A little more diagnostics, not carburetor, swapped the one from my 351, same symptom. Can't get saw above 12.8k rpm even with the high all the way in. Put the new carb on the 351 and turning 13000 3/4 turns out. Time to dig through my miscellaneous spare parts. I may have got some stuff mixed up. I have some farmertec fuel filters that came in the other day but I have not ran them yet in any thing.
decableguy2000
12:23 AM
WNC
Same symptoms, with new OEM fuel line and after market filter. Pulled the tank vent pills and hosed them off with some carb cleaner and reinstalled ( thought I had and extras but can't find them). Still no 13k rpm.
cus_deluxe
terms of service violator
12:23 AM
Michigan
Im cornfused, is this a lean bog? From the part in the middle of this post, it would seem like you think its getting too much fuel since u turned the H all the way in?
decableguy2000
12:23 AM
WNC
Me too. While cutting it would bog down, pull it out of the cut and it would pick back up and was able to make 3 bucking cuts and do it again, I was thinking it was maybe flooding out, but I tried 3 different carbs, 1 new and 2 rebuilt, the carb works fine on my 351.
Have you done this again since it started acting up?
Not yet, was planning on doing it some time today or tomorrow, after I verify tank vent is working properly.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
11:23 PM
Provencal, Louisiana
Im putting money on the tank vent. I had a 390 do the exact same and it was a partially plugged vent that was starving the saw after a few cuts
decableguy2000
12:23 AM
WNC
Tank wont hold pressure or vacuum???!!! O vacuum, can build some pressure but not like the manual says.
decableguy2000
12:23 AM
WNC
Is the muffler screen clean?
yes
90% that is good, my plug adapter is leaking per the bubbles, need to make a new one. However these are numbers I have for now Pressure 10psi to 9 in 2.5 minutes, vacuum 10hg down to 7.5 in 2 minute range.
Replaced the impulse hose today, pulled the cylinder and verified the impulse route. Managed break the intake where choke rod runs through it. I'm going to ordera ne carburetor flange, due the fact I'm wearing out pulling and swapping the carburetor
beaglebriar
The Peanut Gallery
12:23 AM
Warren Center, PA
Drill the vent out and put on of these in it. Then you'll know it's working properly.
