PogoInTheWoods
- 4:59 PM
- Apr 23, 2016
- Ohio
Got most of the parts I ordered for a 3120xp project and am now in rebuild mode. 'Bout as straightforward as it gets except the little trigger lock pin assembly (high idle, throttle catch, whatever you want to call it) has me sorta stumped. Can't find anything definitive explaining how it actually fits into the handle, where the spring goes, etc. It's currently rednecked together and works but was also popping into high idle position on its own occasionally when the throttle was held wide open. I have the correct parts but could use a good pic of what this should really look like when assembled (or a concise explanation of how it goes together correctly with the right parts). Pretty sure there is a small machine screw missing from the OEM kit that would secure the knob to the post which in turn would secure the spring between the trigger and the knob....
Don't see one in the IPL, though. And the inside of the pin doesn't seem to be threaded, either.
TIA for any help.
TIA for any help.
