288xp
RoyleRobinWood1
12:57 PM
Need help with mounting the worm gear on to the oil pump . I have read the shop and service manual and from what i have read . It states that once the oil pump and seal have been assembled the worm gear is supposed to thread into the oil pump like a 394 does , but when i attempt to screw it on it wont go down and seat square on to the oil pump seat
Sent from my SM-N960U using Tapatalk
srcarr52
3:57 PM
Iowa City
We're probably going to need some pictures to see what's going on. There are two styles of worm gears for the 288.
The old system is a gear with an external seal on a steel lip that is pressed into the pump housing.
The new system is the black gear with the integrated dust shield (same as 394/5) that you have to remove the steel lip that is pressed into the pump housing to use.
RoyleRobinWood1
12:57 PM
Ok , i figured this out by looking up numbers and stumbling upon a picture of a 181 worm gear ... i then modified the new worm gear by cutting off the outer most forward washer like face back to the inner face of the worm gear . Then i deepened the groves of the threads and it plopped right in , then i used the cut off washer looking peice to go between the clutch drive sprocket and the worm gear . Basically like what is on the i.p.l for the husqvarna 181 . I also tried to upload pics but the TapTalk app wants me to pay $ to do so. Also the pic's won't upload cuz the site says im not a member ? Which i thought i was but its OK . I think i fixed this problem for now . Thank you
