288XP Lite leaking from fuel cap
Mark71gtx
2:58 AM
Fuquay Varina, NC
My 288 loves to leak fuel from the fuel cap. I bought a new on at a local saw shop a while back, and it still leaks. I am not sure if the cap was OEM or a knockoff. Would the OEM replacement caps say Husqvarna on them anywhere? Are they less likely to be leakers? I would like to stop storing this saw on its side...
Mark71gtx
2:58 AM
Fuquay Varina, NC
Here is a pic of the saw. The cap looks right, but maybe poor quality?
Redfin
Meh...
2:58 AM
Central Pa
Pick up a "new" style cap. They have a rubber grommet that seals side and bottom edge.
Mark71gtx
2:58 AM
Fuquay Varina, NC
Wouldn't happen to have a part number or know what saw I could tell them the cap is for would you? Thanks!
wcorey
2:58 AM
ma usa
From what I've experienced with my own saws is that the tank expands, probably from ethanol, and results in a loose fit with the cap o-ring,
You need the newer style cap with the improved type seal. I've probably replaced 2 dozen of them, with both oem and aftermarket, and it has worked every time.
I've also tried to source over-sized o-rings so to use the old caps that I have a draw full of, but so far no luck. Have tried metric and standard sizes but always more or less the same size or too big to fit within reason.
Mark71gtx
2:58 AM
Fuquay Varina, NC
Thanks. I am running only premium non ethanol now. I got tired of replacing fuel lines and diaphragms. I have too many saws for that crap...
Mark71gtx
2:58 AM
Fuquay Varina, NC
Just tried the cap from my 455 Rancher. It fits. I will order a set of caps for it.
