28" Tsumura lite shorter?
2:11 PM
NW CT
Just run an 8 pin
I’ve noticed the same. Its more apparent on other manufacturers as noted. I did see where most of the Echo 590/600/620 come with a 20” 70dl bars but there are some that came out of the box with OEM Echo bars that were 20” 72dl. There was a transition at some point although I don’t know which came first.
Homemade
2:11 PM
Wisconsin
Old Stihl were fat tips but since about 2015 Stihl has transitioned to the slender 11 tooth tips.
It’s difficult to even find the larger replacement tips anymore.
I <3 Big Tip Stihls: they are the best for Bore Cutting.
Sent from my iPhone using Jon1212 Pro
My dealer can still get the 13 tooth tip. I just ordered one this summer. I’ll try and find a part number ......
1:11 PM
Just run an 8 pin
Ive always known ECHO to use the D176 on there biggers saws. Ive had a 500evl 800 and know the 590 uses that funky 70dl. I haven't seen a D176 20" 72dl yet but its about fugging time.
deye223
AIR FUEL SPARK VROOOOOM
4:11 AM
Australia
It's all we get in Aus is the 13T except the lite bars they have the 11T .
Part # 3003 650 2539
1:11 PM
20" bar 3/8" 72DL should be standard in the industry. All this special stuff for each manufacturer is bull crap. Set a standard and have everyone use it.
and a 24" d176 is 81dl
Which one was 1st for 20”?
70dl or 72dl
Good question
hseII
Heef
2:11 PM
West Georgia
I’ve a 13 tooth 91 DL 0.063” that went AWOL, ( not the Alan kind.)
I wish I could find it.
Homemade
2:11 PM
Wisconsin
I bought a 84dl Stihl branded bar for $20. When I asked the owner if he ever changed the tip, he said they rarely ever ware out.... so I knew it was original tip. One new tip later and I was $50 into it for a $80 bar. I was happy.
Semotony
1:11 PM
Gotta have something to do with the hole drilled for the chain adjuster. Must be slightly different.
My 60" Cannon lists 185 dl's, adjuster hole is a bit big & archer chain was longish and after stretching had to bring is down to 184 which may have been possible at the beginning. Archer hasn't stretched more after original, yet.
