HELP! 28" Chain Dilemma
FernGreen
10:23 AM
CT
Is it possible to make 28" chains work on both husky & stihl mount bars. I would like all my 28" chains to be interchangeable between both my 462 & 372. If I shorten a 93DL chain to 92DL will it work on both saws or am I f*cked?
context:
Stihl mount requires 91DL
Husky mount requires 93DL
hacskaroly
2100 Fanclub Member
7:23 AM
Northern Idaho, Ehh
I would imagine a 92DL would be quite tight on the Husky, but work out as it stretches, unfortunately it may stretch past what the Stihl can handle and become too loose. I wonder if its is possible to put another adjustment hole in the stihl bar a little bit behind the original and "lengthen" it slightly to handle a 93DL or same for husky, put it in front of the current adjustment hole and "shorten" the bar to handle the 91DL?
FernGreen
10:23 AM
CT
Good idea! I might try this
Philbert
Chainsaw Enthusiast
9:23 AM
East Dakota
The bar ‘tail’ / mount pattern; the bar profile and nose radius; the location of the bar mounting studs; the number of teeth on the drive sprocket; etc., can all affect the number of drive links required.
But, using the same bar reduces some of these variables.
Philbert
brushwacker
10:23 AM
NW IN, USA
context:
I had several 009 Husqvarna mount bars machined to fit Stihl and most took 1 link less then original Husqvarna took. My 28 inch went from 93 to 92 mounted on stihl.
Now if you did that for your Stihls , I expect after you run them a while they would stretch enough to fit the 93 link on the Husqvarna.
If you buy Stihl mount bars and use the adapter to Husqvarna maybe both would use 91 or if happens if u need 92 on a Husqvarna, the stretched Stihl chains could be used on them.
Also you can change sprockets to gain adjustments.
10:23 AM
context:
You'll find that different manufacturers and even sometimes different vintage bars from the same manufacturer's demand different drive links
I've had many like this and especially 28" bars for some reason.
10:23 AM
I have a 28 inch cannon that works on both with a 91 DL chain. I do not know if it is a little bit longer or shorter than a stihl bar. It does have a longer slot obviously because husky bolts are spread further apart
4:23 PM
Stihl 12mm mount bar that came with a PS-7900 purchase, note the additional oiler hole drilled.
I did not check whether it was needed or not since I have no intentions of utilizing this bar other than for flat steel stock.
Picture shows the bar fitted onto a PS-7900.
Bar adapter is my creation.
STOVE
10:23 AM
Eastern NC
My Dukes semi pro bar is 92 links, weights 3.2lb
