28" .404 8pin chain comparison w/661
junkman
Crush it
6:27 PM
pacific northwest
I would rather have a slower chain for work if it is smoother and lasts longer ,too grabby makes tip cutting and bore cutting not good .
Great test redbull
Is it possible to get images of the cutters on the test chain to see what angles are making what times ?
Joe Kidd
I reckon so
9:27 PM
NC
My seat of pants clock sees it dead even. Smoothest on the operator wins.
9:27 PM
Oregon makes them.
jb-chainsaws
2:27 AM
UK
30 10 37 - felt most like stihl factory
20 20 40 - very smooth. gotta hand it to @junkman but at the same time I gotta wonder if 25 top plate wouldn't be even better! yes yes I know capt. perfectionist at your service. :p I'll have to beg @big t double to make one! :biggrin:
and here are some side by sides - 20 20 40 on the left, 35 15 40 middle , 30 10 37 right.
That 20 20 40 has got me really interested, I'm guessing that'd dull a little quicker with the top plate angle? I may give it a whirl, always interested to try other guys USG numbers
Edit: ignore me, got me numbers backwards! :borra2:
junkman
Crush it
6:27 PM
pacific northwest
Actually the opposite ,it will last longer in my opinion ,the straiter across can get the top plate ,the longer it will stay sharp ,you get a stronger outer corner doing this ,this also smooths the chain out so not as jerky in the cut ,i mill with the same angles i run for cutting now ,because they hold up and make a smooth cut ,off the roll rsc bogs my 440 saw more than less aggressive angles do ,work and race chain are 2 different things ,how much work are you really getting done if have to swap chains every tank ?The square i am running is actually smoother than the 20-20-40 round ,and is more forgiving on a smaller saw ,i am running .404 with a 32 inch bar on a 440 hybrid and it zips around the bar just fine because of the angles i use .
20 on redbulls chain is the top plate angle ,the other 20 is the vise tilt ,the 40 is the grinder wheel angle .
junkman
Crush it
6:27 PM
pacific northwest
If go 25 on top plate it may cut a tad faster ,but will dull quicker than 20 will ,it is all compromise ,it will be grabbier also .
Tbrown
8:27 PM
Eau Claire, WI
Julian. You can take my grinder and grind all you want. Will have to wait a few days. Eating breakfast in Eureka CA right now.
