Yup.. thats what i was getting at. Early ones seem to have a small washer rather than the big disk.Do u mean part #503 52 12-02 in the above pic? If so then yes I have it. I'll post a pic of the serial number plate though nothing will match. Tank, case, cylinder, clutch cover are all each from different saws.
The band spring sort like you have on the 262 are not hard work to put together at all I find . The hole lot shouldn't be real sloppy once its together or you get drag ...some spring pressure is needed but you wont be fighting to put the clutch together with your hands. IMOit is normal to be able to just put the spring on by hand. Not real tight like on other clutches.
the only concern about that clutch is if the chain engages at too low an rpm... so if the idle is nice, but the chain is spinning, you know you have an issue
Got the rivets out of the old tip. What a pain in the ass. Any advice on the best way to flatten the new rivets?
I swapped the oil pump for a spare I had so we will see if it still leaks. I have a feeling that the oil line from the tank is not sealing properly
Ready to sell that nice problem saw yet?Got the rivets out of the old tip. What a pain in the ass. Any advice on the best way to flatten the new rivets?
I use the flat end of a drift ... about 1/4" diameter.
If you don't have 501 62 43 from the diagram or an o-ring has been subbed in, that'll cause a leak too.
Ready to sell that nice problem saw yet?![]()
Do you have the part numbers for the clutch drum and worm gear? I have a 1990 and might want to change that out as well. Thanks.Thanks! This has been a fun project. I used a combo of heat gun, sanding and pliers to fix the melting/warping of the cylinder cover. It's not perfect but looks a lot better now. I also updated clutch drum and oiler worm gear to the newer style so it won't oil while idling.
welcome to OPEDo you have the part numbers for the clutch drum and worm gear? I have a 1990 and might want to change that out as well. Thanks.
Awesome. Thanks.welcome to OPE
I've only seen one style crank to 262, if there isnt anything I've missed you can study IPL's from the 96 model.
Parts tree have updated their website, there is a few errors there nowadays.
https://www.partstree.com/parts/hus...2-husqvarna-chainsaw-1994-06/oil-pump-clutch/
https://www.partstree.com/parts/hus...2-husqvarna-chainsaw-1996-01/oil-pump-clutch/
If we do study those two for 325, we see that worm gear #
503557801 is the same on them.
Clutch drum 1994 #503646601 has been updated to #503646604
Study year 1996 you'll see that those two numbers match
https://www.partstree.com/parts/husqvarna/parts/503557801/
https://www.partstree.com/parts/husqvarna/parts/503646604/
Sorry blew right past that diagram was trying to read the whole thread before bed...If I'm not mistaken they should be in the parts diagram pictured at the top of this page. If not check ereplacementparts or parts tree websites. I got mine on ebay. Mine phone is about to die otherwise I would help more lol
