261cm or 261? and how hard is it to pull limiter caps on 261
Stihl Potlicker
11:43 AM
P.A.
who has both a 261cm and a 261? and what one do you like better?
Stihl Potlicker
11:43 AM
P.A.
I take it I hve to take the carb off? They look like they r cast aluminum. On my 461 they were plastic and I could take them out with carb on
CR888
1:43 AM
2mm hex, jam it in and turn them ccw/cw to wherever you want the new adjustment range. Done! You need not remove anything. Its an ol M/M trick but read the Stihl factory dealer service manual & that's how they do it. You can order an OEM tool which is a 2mm hex with a screwdriver handle. Boom...mic drop.
I have a couple of standard carb saws, I could have bought MT's but chose to order them in regular carb. I am happy with my decision as I suspect many who bought MT saws are too.
Duane(Pa)
It's the chain...
11:43 AM
Centre County
I remember doing this back when I owned one. If you want to richen the high, you just insert the 2MM allen and “sprag” the spline. Sort of forcing the screw beyond the limitation. Poof you’re done.
sawmikaze
11:43 AM
steeltown
But if you feel the need to pull them...
Stihl Potlicker
11:43 AM
P.A.
I have an older 261cm and I am happy with that one so I bought a 261 last wk
Chainsaw Jim
Con Artist LLC
8:43 AM
Springfield Oregon
You do not remove or pull the metal limiter caps on the 261 carbs. As mentioned above, use a 2m hex. When it gets to the end of the limit you apply more force and it'll make a clicking ratcheting noise the rest of the way and continue turning. The entire piece turns and stays together.
