WANTED 242/254/262 XPG Generator
Derf
6:40 AM
Long Island NY
Looking for a stator/generator that goes behind the flywheel in good condition.
Also looking for a heated handle switch.
Derf
6:40 AM
Long Island NY
That wasn't what I needed, it's the wrong size and bolt pattern.
Bump
Glock37
6:40 AM
Monroeville Pa
On 242 make sure get sleeve and seal needs to be set deeper
Glock37
6:40 AM
Monroeville Pa
Switch same as 395
Generator same as 395
Derf
6:40 AM
Long Island NY
Thanks for the suggestion, but apparently that one didn't fit either. Should have known, the 394/395 generator has a different part number than the 254/262 part number.
For anyone curious, this is what a 242/254/262 generator looks like.
This is what a 395 generator looks like.
Notice that there needs to be 3 mounting screw holes that line up, AND, the center hole is just barely bigger than the shaft diameter. For anyone coming down this road in the future, don't waste your money buying the wrong part - they don't cross over.
Spike60
6:40 AM
Ulster County, NY
Fred is correct that the 395 item isn't going to fit. I don't have anything laying around myself. Experimentation with 346/357 or 550 generators might yield some results, but they'd be pretty expensive experiments unless you already had them laying around.
jockeydeuce
3:40 AM
BC, Canada
If I was a betting man, I'd say that's the same stator as an 028 etc. Stihl....
I've got a new one
TUBBER 340
3:40 AM
Nanaimo BC
I’ll look in hr and let you know
Derf
6:40 AM
Long Island NY
I've got a new one
They do look Very similar. Can you take a pic of it from above next to a ruler and PM me the pic. I’ll scale it to size and print it, cut it out and lay it on the case to see if it would fit.
jockeydeuce
3:40 AM
BC, Canada
Don't know if this helps enough....outside is roughly 2 1/8"
jockeydeuce
3:40 AM
BC, Canada
That’s perfect, but it says SEM Sweden on it... is this a Husqvarna part, or a Stihl part? I was curious if the Stihl part is easier to source if it will swap over.
Mine is a Stihl part....# 1118 400 4000
Mine's for sale if it will work for you
