2013 Ford expedition front right brakes wearing out fast.
lehman live edge slab
Live Action
1:07 PM
Mn
Rotors are made as cheap as possible these days, I remember turning them back in the day.
Me too, did them at my uncle’s garage right on site l. Problem was they had rust in the venting and even if they met minimum thickness spec the would re warp really easily if they were hot and then hit water ect. For this reason he quit doing them alone with being liable if something happened.
dangerousatom
2:07 PM
Quakertown, PA, United States
Don’t forget…. Should change brake fluid about every 5 yrs. I know that’s not your problem but a truck that age is probably due.
^This For Sure^
Dyeing the fluid helps speed up the bleeding process.....color the bottle not the brake reservoir fluid. Once your fluid turns to the dye color you know its flushed! This is BLUE dye for like $10 bucks. That little bottle is a life time supply at 7-8 drops in a quart of brake fluid.
