2011 husqvarna 562 high end bog/stall???
12:03 PM
I still have a quadrajet 4 barrel in my shop with some sort of plunger solenoid from the looks of it mtronic/ autotune copied that design except the truck had an 02 sensor...
plunger solenoid for high idle when warming up ?
12:03 PM
Had an 85 Mustang GT with electronic carb, could not get it right when it gave us trouble. That was the last year for the carb 302, and only if you ordered the stick (which I did), the auto was EFI.
Also, my brother and I plugged a whole lot of those air injector pump FE heads. Luckily, you could buy flush fitting plugs right from Ford. They sold them so you could use a new head on an older engine. We also always replaced the points & condenser with a Mallory photocell electronic ignition. The kit bolted right on to your stock distributor and was supposed to be good for 9,000 RPMs. Most of the FE motors limited out at 6,800 RPMs (due to the heads), so we were good.
