2 Series Husqvarna top cover thread repair
Gary Courtney
12:32 PM
Froglevel
261 Husqvarna
503203228 SCREW
272 Husqvarna
503203228 SCREW
I copied these from there prospective IPL's, so I'm going to say for sure they are 5mm as I know the 272xp is.
where did you find marinetex
jakethesnake
I Am The Snake
1:32 PM
Here & Now
F4450B22-A85E-4E04-B302-D79FDE653FC5.jpeg BC6B65C0-32B2-4AEC-8130-DA84C5CD4F95.png These do work well in 288s
Here’s what you can use as an alternative
Be very freaking careful.
There’s enough room to drill and tap these in.
There’s no extra room but there is enough.
This should be stickied somewhere @Mastermind
I had to google search to even find this thread.
This sorta stuff should be front page news not stashed in the bushes.
jakethesnake
I Am The Snake
1:32 PM
Here & Now
Kiwioilboiler
346 Pic Examiner
5:32 AM
Marsden Pt, NZ
I have filled a couple of holes for the top cover screws on my 288 with JB Marine.
Those that have drilled and tapped for a helicoil, did you risk a handheld drill or go to the trouble of setting up for plumb on a drill press? I'm thinking the travel limits on the drill press could be beneficial, but a tape-wrap on a drill bit is time proven too.
Member
12:32 PM
I've just used a cordless drill as I have a small drill press. I would say let your equipment be your guide.
Nutball
12:32 PM
Mt. Juliet, TN
What about just gluing an insert (press fit, or threaded) into a freshly drilled hole with JB instead of the extra step of tapping the epoxy? Would it work well? I'm not sure I want to buy an other tap for fixing one saw if I don't have to.
jakethesnake
I Am The Snake
1:32 PM
Here & Now
I think it would work.
