Homemade
- 2:27 AM
- Apr 8, 2017
- Wisconsin
I know this may seem fairly simple, but if I run 2, two stage pumps on my logsplitter. Can I just tee the pump outputs into the valve input? Will in need to add check valves between pump and tee to prevent one pump pumping oil backwards threw the second pump when only one is running say on start up.
I’ve been tossing around the idea of making some upgrades to my splitter. 36”x4.5” ram. New wedge design for interchangeable 4 way or 6 way wedges to slip on. I want to go with a 22gpm pump. The engine I would need will push me into the 16hp range. There is nothing wrong with my current 5hp 11gpm 2stage set up now. It will be much cheaper to purchase a second 5-6.5hp engine and 11gpm pump. I just want to make sure it will work in tandem and not fight each other.
Btw I will plumb in two separate intakes for the pumps from the tank.
