181 288 fuel line direction???
Mattyo
Youtube speciawist
6:39 PM
Farmington, CT
Man I feel like an idiot. I'm trying to figure out which direction an OEM husqvarna fuel line goes in this 288/181 tank. One end is chubbier than the other. Its their proprietary line, and I assume the chubby end goes into the tank, and the skinnier end I pull through from inside the tank to the outside... yes, no?
Mattyo
Youtube speciawist
6:39 PM
Farmington, CT
thanks but that doesn't appear to help
or did I miss something?
Mattyo
Youtube speciawist
6:39 PM
Farmington, CT
5014265 is the number on the fuel line. I've tried to pull it through but it won't go. The tank opening is 7.2mm. I had to open it to 21/64 before it would actually accept the line. Now it's in an solid.
There goes 30 min :(
XP_Slinger
They’re Just Saws
6:39 PM
Central NY
It seems like there is a newer tank that takes a different vent and standard fuel line. Could be wrong though
XP_Slinger
They’re Just Saws
6:39 PM
Central NY
Nope you are correct, newer tank takes pig tail fuel line, you can use a grommet from a 455 rancher to put the pig tail on the older tanks also
Nice trick on using the grommet when that pesky proprietary line can’t be found. Now that I think about it, the tank on my 288 uses pigtail fuel line...duh!
