066 build
Galexy
Active OPE Member
7:36 PM
Rogers, Arkanses
Im wanting to get my 066 built spicy work performance build. What are some killer quality parts
Loony661
462’s 4-LIFE
7:36 PM
Winona County, MN
Get it ported , by one of our fine saw builders on this forum, No.1 👍
This, and be willing to wait. The good porters all have work lined up for a couple months or more. Do your research in the builders thread, get in contact with them, and be patient. It’s worth the wait.
Galexy
Active OPE Member
7:36 PM
Rogers, Arkanses
Thank you for thr advice. I have noticed the good porters and builders are stacked.
Powerstroke Cowboy
6:36 PM
Montana
The killer quality parts would be OEM.
If you want more power, go all OEM and port it, do an MM, as well as intake and carb work. It'll be a runner for sure.
Galexy
Active OPE Member
7:36 PM
Rogers, Arkanses
Its been a minute that i have been into saws. Getting back into to it though. I was looking into metor and wisco for the aftermarket stuff. Im gonna have it done from the ground up. I just want it done correct
smokey7
8:36 PM
Detroit
Only thing to be sure to check with the type of rings you get with your weisco piston may not be compatible with the plating in the cylinder. OEM Stihl plating with the chrome faced (I think) Rings will tear up the plating in short order. I am unsure if meteor plating will handle the rings. I thought I heard Dave at CCC had caber rings to fit the weisco or was working on a caber solution.
ManiacalMark
8:36 PM
PA
Pretty much all the wiseco stuff will have a chrome faced ring which won’t work without a cast iron bore.
