064 ignition
066 redeye
9:47 PM
Tasmania,Australia.
I get all my OEM parts from Bill aka outbushman on ebay in Western Aust.
Cheaper than my local dealers (Tassie).
He has the 1300 coils.
But you can try a Chi one if you want.
But hit and miss.
Chris.
jacob j.
Only the weird
2:47 AM
Coastal Oregon
There are 2 types of coil mounts for 064 cases.
You may or may not need to make a bracket.
If he's got the 1303 ignition (which is what his looks like) then he can swap the universal ignition straight in with the right flywheel (or timing).
jacob j.
Only the weird
2:47 AM
Coastal Oregon
Neil -
I struck out on the 1303 coil - mine's dead. I did find a good 0000 400 1300 coil (what we call the "universal" ignition)
which I can send your way. Then you can try Chris's trick of re-timing your 1204 flywheel without having the key in.
No1spike
Active OPE Member
9:17 PM
Neil -
No1spike
Active OPE Member
9:17 PM
Cheers Jacob, I appreciate that so much
How do you want me to get some money to you?
jacob j.
Only the weird
2:47 AM
Coastal Oregon
Neil never checked back in, and he didn't answer my PM, so he must have worked something out.
No1spike
Active OPE Member
9:17 PM
Hi Jacob, Sorry for not getting back to you guys, but I put it in the to hard basket for a while.
I’ve managed to get a 1203 flywheel and just ordered the 1300 coil. Could I ask which key way to use when setting this up?
Cheers
Neil
president
2:47 AM
peachland BC Canada
I'm in the states Neil. Yeah, German or UK Ebay might have good parts. If this coil here tests out good, just pay shipping on it and it's yours.
I've got assorted small parts left over from 25 years of rebuilding 064/066s.
Jacob
I have a 1309 coil from a 046, and same one on my 2001 066
how were they for reliability?
jacob j.
Only the weird
2:47 AM
Coastal Oregon
Cheers
Neil
If it has a keyway marked "X" or "B", that should be the one to work with the 1300 module Neil.
The keyway marked "P" is for the rev-limited coils.
Jacob
Keith - The 1309s are the hottest running coils for the poly flywheel saws but they burn out more than the 1122 400 1314 coils.
If it has spark, then it should make a good running saw for you.
president
2:47 AM
peachland BC Canada
thanks Jacob,I think I have a 3 pole backup 1312
appreciate it !
No1spike
Active OPE Member
9:17 PM
Thank you I will try it out on the weekend and post the result.
No1spike
Active OPE Member
9:17 PM
Hi Jacob, finally got around to putting the new flywheel and coil into my 064. It is running like a dream again. Thank you so much for all your help along with input from others. Yes I tried the no key in the flywheel trick and it does work but I have put the key back in now.
Regards
Neil
