046 big bore
StihlEchoingHusky
4:37 AM
Looks good, nice job! What cylinder did you go with?
It's just a hyway titanikel big bore and at that a free porting cylinder. Sure does rip though. It will be a OEM again here very soon right after I finish buttoning up my 365. Yes My 365 looks off color wise damn previous owner painted the engine cover and the clutch cover. It all says made in Sweden though haha (farmertec pro trigger idk why but I like them)
StihlEchoingHusky
4:37 AM
Is the titanikel hard to work with when porting?
Diamond burrs slow speeds. Foredom Vstones work aswell and foredom blue ceramics work really good for port chamfering. I honestly prefer the ceramics for chamfering vs diamond it comes out cleaner on any of the plating. Atlease that's what I've found
Jake Dykstra
4:37 AM
NW Washington
That sounds good!
I went with a 66 piston in mine. Longer skirt allowed for chamber/base cut.
Runs pretty good but damn that thing drinks fuel like a nitro car.
Which is weird cuz my bb 390 sips fuel like a prius and makes more power. Guessing the port work i did is more efficient on the 390 is all i can figure.
I've had great luck with the titan nickel cylinders. That said I take way to long to port a cylinder.
StihlEchoingHusky
4:37 AM
That sounds good!
I've had one titanikel failure. Burr had broken teeth. Other than that I've had good luck
StihlEchoingHusky
4:37 AM
That sounds good!
I haven't broken it in yet to where I feel comfortable enough to put it in wood but here's a ms250 titanikel pre portwork 🤣. Got the saw for free with Burnt piston and cylinder. The titanikel was on sale. It's probably the cleanest aftermarket jug I've come across. a cross performance 372 xtorq was just a tad nicer. I definitely prefer OEM but I do like to play around and find what works and what doesntScreenshot_20241221-204345.pngScreenshot_20241221-204355.pngScreenshot_20241221-204407.pngScreenshot_20241221-204413.png
StihlEchoingHusky
4:37 AM
here's the OEM cylinder with a meteor piston.
I know clarity is garbage. I didn't realize my lens was so filthy. The rain stopped presenting me an opportunity to record a video. I was in a hurry before it started back up
Jake Dykstra
4:37 AM
NW Washington
I agree with learning on the cheap ones. Sometimes the port timing is a bit different but can be ground to mimic the oem ones. I figure if am makes good cranking compression and ports can be ground similar then they can work just as well and make excellent training or race cylinders.
Yep sharp burr is the key to success
StihlEchoingHusky
4:37 AM
Absolutely! Ive learned to go slowly at first. Now I won't touch carbide to any sort of plating. Doesn't matter if it's OEM nikasil,chrome aftermarket nikasil or titanikel. I grind plating away with diamond burrs and foredom v stones. Once the plating is gone I will finish up the stock removal with carbide. I think the biggest problem people have with titanikel plating is they go at it with carbide burrs. Single cut is like taking a high speed pry bar to it and double cut is like picking it off with a flat head screw driver. Diamond burrs at slow speeds is what it takes. Sure it takes longer to port the way I do it but I haven't had any plating flake off going this route.
