Adirondackstihl
- 8:21 PM
- Dec 4, 2015
- Upstate NY
Wonder if there is a wider pin bearing that would fit the piston better ? the rod should center itself where its happy at .
Aren't the meteor pins in a different spot ? like the 12mm locations ? I was just thinking as an option to use a later 440 jug on a 10 mm sawI can now get OEM cheaper than meteor so I'm happy to use the right tool for the job.
I'm not saying the OEM isn't a better choice which I think it is, but the price comparison isn't apples to apples is it?I can now get OEM cheaper than meteor so I'm happy to use the right tool for the job.
Found this slop in a few different saws running the old HyWay pistons before they were updated some years back. Rebuilt one that had that Meteor piston and you lose 1/3 of the bearing surface contact area with that set up. I'd bet it's fine in a stock saw tuned correctly. This saw must have done a lot of felling because the edge of the bearing cage was sharp as a razor on the pto side. The piston had excessive wear on the inner boss area of the pin wall. The Meteor piston was wore out when removed. The HyWay had the same play as the Meteor.
It's definitely a manufactures attempt to use a universal piston in 10 or 12mm.
Has anyone checked this on other pistons like the newer HyWay or other brands?
Maybe I was referring to the hamfisters who have a different idea about how to work on saws.If you check to price of OEM, I don't think you will bother.
lol sorry...my head hurts.
