Nutball
- 11:36 PM
- Oct 31, 2018
- Mt. Juliet, TN
I was told it ran well, then wouldn't restart. I thought vapor lock, but it had cooled down, so then I thought it's flooded because he said he turned the screws 2 turns out. I aired out the engine, closed the needles, it has spark, the flywheel magnet seems to line up with the coil at TDC like my other Stihls, compression is 120psi, piston and cylinder look very good. I tried ether, even with some extra oil on the piston to help compression, which got a badly scored poulan at around 80psi running in the past, but not a single pop out of it.
What think you?
What think you?
