Mark71gtx
- 11:16 AM
- Jan 14, 2016
- Fuquay Varina, NC
A friend dropped off his 028AVEQ saying it was sick. I took it for a spin today and he is right... It is blowing 150psi and passes pressure and vacuum tests. The saw just don't have any power. The clutch had weak springs, so I replaced them. The drum is in good shape. The sprocket is in good shape. The chain is not the sharpest, but I have tested worse and had better results. You have to fight the saw through a 6" limb. It is just weak as hell. Carb is a Tillotson and is clean, with pliable diaphragms. I have not changed the plug, but the plug looks good with a tan colored electrode. With this info and symptoms, what is your best guess as to the culprit?
