026 refuses to idle
Mark71gtx
5:33 PM
Fuquay Varina, NC
@Chainsaw Jim I set the L at one turn out as a baseline and attempted to get it to run by leaning and richening way more than that screw should ever be turned with little to no results.
RI Chevy
5:33 PM
earth
The way you are describing it now, definitely sounds like an adjustment issue. The 1 and 1 turn out for H and L is a guide, but you are using a different carb (Chinese knockoff).
You have to keep trying until you get it. Back the LA way out and keep trying.
5:33 PM
i am like al and keep spare carbs around i just did a 026 took off a 194 and put on a new 194 ill rebuild the old one for a future project time just wasnt on my side then
RI Chevy
5:33 PM
earth
See if you can get a good working carb and try it to rule out other potential issues. See if the saw runs correctly with the good working carb. That would be the next logical trial I would think.
Mark71gtx
5:33 PM
Fuquay Varina, NC
I put the Tillotson back on and now it runs like it should. Freaking Chinese garbage... the coil wire feels broken right where it screws into the coil. I bet that was the problem all along...
RI Chevy
5:33 PM
earth
Just replace the coil wire.
Glad to hear the carb took care of the issue.
psuiewalsh
Basement Bodging
5:33 PM
Nottingham,pa
Would an inline spark tester have detected this? I try one prior to leak testing on saws with odd issues.
Mark71gtx
5:33 PM
Fuquay Varina, NC
It was sparking, but it was apparently intermittent. I had pulled the plug and layed it on the cylinder to check for spark and it looked okay. It wasn't okay enough though...
