Don't know. I am assuming I need the block off plates to do the tests. I make them for my other saws but I'm not sure how a homemade version will work on these saws. They sure didn't work on my 576xp.pressure and vac check ok ?
Inside of cylinder. Nothing that even catches a fingernail.Yrs I would
Absolutely.Looks like carbon scoring. That's auto tune right?
Seems to be a rub. Wish it was a rub of Copenhagen in my lip but I quit 5.5 years ago.Can you hang a finger nail in it or is it a rub
I knew it had a score on piston upon purchase and happened to have time to remove for inspection.Was it running right and you just happened to pull the muffler? Or low oncompression/running poorly?
No they make special security bits for those. You should be able to find them at any tool storeIf I want to inspect the transfer gaskets, do I need to drill out the dimple in the heads to remove the bolts?
Sorry missed this. Yes sirShould just be a "security" type torx bit right?
