Will a Stihl 3003 bar fit a Dolmar 6100 K095 with bushing the studs up to 12mm
Adamski
Plebus Splederns
3:38 AM
Essex, UK
As above, wondering if a Stihl bar can be made to fit, do the oil holes and tensioner holes line up etc?
Cheers.
AlfA01
5:38 AM
Evia, Greece
I don't see it as being a feasible mod. The tail of a K095 is relatively slim compared to even a 3002 Stihl. Adjuster holes and oiler holes are way off.
9:38 PM
Adamski
Plebus Splederns
3:38 AM
Essex, UK
9:38 PM
Me too. And the uk ‘Makita 6100’ that I have came with a 18” .325... and the bar has a smaller radius tip than the .325 x force bar on the wee ps-420..
Go figure.
20” 3/8” versa cut bar and 21lpx chain ordered.
I think you want 72LGX or ELX. LPX is .325 iirc
10:38 PM
Go figure.
Try stihl RS .325 on it. You will like it much better than lpx.
00wyk
3:38 AM
Ireland
Thats still a D type tail shape in Oregon speak like the D025 Stilh and D009 Large Husqvarna. It could be made to fit the bar studs but the oiler holes still would be off.
Is the gutter too far off to redrill?
00wyk
3:38 AM
Ireland
You are right, I mean lgx chisel. [emoji106]
Is that puppy ported? Otherwise, it's a bit of an ask chunking a 24 inch bar on it in 3/8.
Adamski
Plebus Splederns
3:38 AM
Essex, UK
No brand new. I am toying with just using a 20” on this stock and using my 064 for milling and anything bigger than this wants to cut. So it seems I will be binning the 24” option.
00wyk
3:38 AM
Ireland
It could probably work but then you have to have 81dl for a "24 amd 70dl for a 20"
I ran an oregon 176 on my 262xp in 22" with the stupid DL# and tight tip on it. The saw did not like it at all.
