I had gifted him the saw. He’s a good dude and was in need.Nice. Give him an 029 Farm Boss loaner next time. Keep the 026 for yourself. LOL
Right now a 4.3 Litre marine engine in Dads' bowrider is what I am wrenching on. Cleaned the carb and got it to fire off last weekend, pulled the dipstick and it looked like chocolate milk. Pulled the drainplug and about a gallon of water came out before any oil. Flushed the crankcase with Kerosene and re filled with fresh 10W30 and a new filter. Hooked water to it and it wouldn't pull in the engine, impeller is bad. Ordered a new impeller kit and will try again next weekend but I suspect the engine will be coming out soon.
Can you get a crate motor? That sucks Bro!
There must be alot that can be saved from the motor you have. No need to buy new everything.
I put a same year engine from a chevy 4.3 blazer in my Sea Ray (it had a 4.3 LX ), bolted rite up. Had a shop do rings and bearings check the heads.A true Marine crate engine is $5K. I think i can build one for ~$1500.00
One thing he did say it to keep the crank and balancer shaft together, sometimes mix and match dont work on those.
You may get a shake.
The previous engine got froze with water in it , cracked one head and the block.
Good Luck.
Timing??Ok, I am stumped! Can’t get this TS 800 to run. I have spark, I have fuel and I have 168# compression. No air leaks, new fuel lines, new impulse lines, new gaskets, new seals, re did ALL the wiring, swapped coils. Crankcase/cylinder holds pressure and vacuum.
Poured some fuel down the throat: nothing.
Poured fuel in the airbox and sealed it: nothing.
Spun with impact gun: nothing.
Suggestions?
Timing??
Maybe the key is sheared???
Ground wire shorting out somewhere preventing it from running?
