- 8:09 PM
- Jun 5, 2016
- Northwoods of Wisconsin
Whaaaat?
No rebuild and port job?
$$$ vs new model performance. Not a big decision here.
Whaaaat?
You can't go wrong with an Echo weed wacker.$$$ vs new model performance. Not a big decision here.
Well sheeeeit....in that case I really like my 350bt. LolCan when it's a back pack blower that is needed. Lol
You’ll need the two updated green oiler lines if it doesn’t have them alreadyPlanned on running these three today.
Tuned and ran the 6401, oiler seemed to not be putting out well and was leaking out the bottom of the case near the adjuster.
Then it started raining on me. Which was no good for cutting on a hillside.
So I ended up pulling it apart to fix the leak.
Two in one week. Never seen this before. Both from 201T. Two different customers. One ported one stock. HmmmmmView attachment 176963
That HT carb, I want to think I have replaced one of those with the nipple for a pulse line from a 029 stihl, crank case side. I don't remember if it was a direct swap, you may need to drill the carb. Use numbered bits to get it about .002" smaller than the nipple.
Mowers and dirtbikes are ready
Check out the Mickey mouse brake View attachment 176702 View attachment 176703 View attachment 176704 setup
On my tundra put new brakes in as well.View attachment 176711 One of the caliper bolts stripped and came out.
Nephew's 2002 chevy has been through 5 headlight bulbs this time it fried the socket
Passenger side's never went out.
Common issue he was told.
184 international hi boy
Clutch fork broke on both sidesView attachment 176705
