usmcbuckwild
Buck
- 7:48 AM
- Dec 24, 2017
- NW CT
bad advice. Don’t do what I say
The other ring is .016".
It will rev, then you can tell the rpm drops, then back up and down at w.o.t.
Any change of the screws from where I had them it either wont rev up or bogs and falls on it's face.
Maybe I should pull the carb apart. Again.
Hopefully the top ring was the one at .016. If not, it wouldn't hurt to put new ones on. Don't swap them because when they break in to their new positions the gap will jump more yet.
Try cleaning the carb and put a new kit in it. Maybe there's a problem with certain gaskets not having holes exactly where they need to be. Post up some pics of the carb and maybe someone can id the problem. I'm not familiar with the model at all
It was the top ring at .016".
I am not familiar with anything Dolmar.
I checked squish without a gasket, .021".
So for giggles I put it back together.
Pulled the carb apart again. I didnt see anything obvious, but I did tweak the fulcrum arm a bit.
Its a Tilly. I do not have the guage for it either, so I winged it. Carb kit was done already.
Put it to some wood, and it seemed ok.
I am willing to stick rings and seals in it if I know it will run. If not, I will toss it in the field and shoot it with the .300WM.
While I would love to see what a .300 WM does to a saw, I’d rather take it off your hands than see holes in it.
Shoot something useless like an 029/290
I would too!
I think I got it though. Best it's ran since I got it.
Video posted in the "cut report after the bench" thread.
Dont be hatin on the 029. I just sold one for 2fitty.
I despise the 029/290. To me its an overweight, underpowered, turd.
029 goes for $300 but homie won't pay that for an 039. Too heavy lolYeah, but, they sell stupid easy.
I couldn’t sell a BUILT, ported and polished 288 XP but got got almost the exact same asking price for an 029 with a used Stihl bar and new EXL chain.Yeah, but, they sell stupid easy.
You mean the 2 or 3 foot arm and blade? It’s not called a bar silly...I couldn’t sell a BUILT, ported and polished 288 XP but got got almost the exact same asking price for an 029 with a used Stihl bar and new EXL chain.
I never understood the hype on the farmboss. Hard to work on them and a 026 is a way better saw for the $.
And let's not forget, the folks who only want a "Magnum"!!!
345 year 1999.
Top end in good shape, she had a massive airleak though:
They used cheap food oil to lube the b&c, the saw was pretty much full of it
I've tried indexing plugs in saw's I don't believe it makes much difference in a saw now if they had intake and exhaust valves like four stroke then that would be different.I would hazard to guess that you indeed have a bad/on-its-way-out seal and those rings need to be replaced.
This leads to another question: Does anyone else ‘clock’ their spark plugs?
