Ask the guys above, as I always grind mine into sausage. I do not have the time to wait on smoking a whole pork but. Too many hours for me.
I plan on doing it over night on my electric smoker.
At 250 degrees it takes longer than 12 hours to get a butt to 195. This is in my egg though, everyone’s smoker or even thermometer can be different.Wondering why it has to be done over night? It should not take 12 hours to smoke a butt (even if it is 10+ pounds).
Although I fully realize that folks out there are smoking butts for much longer I cannot imagine the meat having any moisture
left inside if it is cooked unwrapped . To rub, or not to rub is a debate among those who cook BBQ. The old school guys I learned under put little or nothing
on the meat before it went on the cooker. There are a multitude of rubs out there. I have used "Butt Rub" which is prepackaged
and available at Academy Sports (on line as well at various places).
My target temperature for finish also depends on when and how the meat will be served. If I am cooking for a group and intend
on serving the meat within 30 minutes of taking it off my cooker I bring the butt to around 195-200 degrees. If the meat is going
to rest wrapped for longer than 30 minutes thats another story and the finish temp depends on how long the rest period is.
The time a butt is cooked is determined by size and temperature of your cooker. My desire is to keep my heat around 250 degrees
and go low and slow.
Once a butt hits 150 it starts to sweat and lose or hold temp. At this point I should wrap it, usually don’t. I try to push through it cuz I have time. Normally end up wrapping it anyway to get final tempI don't own an egg and I totally agree with the fact that every cooker is different.
In simple deference to you sir -- I've never cooked a butt 12 hours but if it takes that long on your egg -- make it happen.
It's all BBQ, and if it's cooked right there's nothing better. Enjoy your meal.
I start mine at 10:00 the night before. Done for dinner the following day.
Yes, 3 chimney starters of lump charcoal and a few good hunks of cherry wood. The divider plate to cook indirect, takes about an hour to get all the charcoal and wood going good and calmed back down to temp. About 250 - 275, let it go for at least 14 hrs then wrap until it’s at least 195, high temp of 203Here's a question about the Egg. Are you using the plate that goes into the grill that allows you to cook indirect on this lengthy cook? Just curious, I have very little knowledge of the Egg.
These were done for 14 hrs at 225*-230*, unwrapped.
I've done them for up to 18 hrs. Never had one dry out.
